Which AVR to choose?
A project log for Hacker's IR remote
A hackable SMD IR emitter
nick-sayerNick Sayer 06/07/2016 at 14:250 Comments
The boost converter portion of the project will be quite straightforward - it'll be a copy of the boost converter in the Crazy Clock based on the NCP1402. It'll be powered by a single off-board AA or AAA battery (at the discretion of the builder).
Next is which AVR to choose, and that choice comes down to the ATTinyx4 or ATTinyx5. And which of those to choose comes down to how many buttons are desired.
We lose 3 pins of the controller to power and !RESET (while you can turn !RESET into a GPIO pin, that means you can't program the chip conveniently after you do so). We lose another pin to the IR LED. We're left with either 4 or 10 pins left.
A joystick (up, down, left, right, and center) is 5 pins, but one workaround for that is to chord up and down to get an extra button. While adjacent directions can be chorded on a joystick, opposite ones cannot, so there's no ambiguity.
But is a joystick enough? We could use a button matrix to multiply the available buttons, but we would need more than 4 pins to do that (a 2x2 matrix is no better than just four individual wires). With the x4 chip, we could use up to a 5x5 matrix to get 25 different buttons.
None of this precludes in-system programming. As long as you don't push a button during programming, those lines would still be disconnected while programming was taking place.
Which direction should we go? A larger button matrix or a minimal joystick remote?
