Ordered more parts
A project log for Pick and place machine
A pick and place machine optimized for small runs of different boards. Up/down looking cameras. Large number of feeders. Fast. Web interface
zeptobitZeptoBit 05/28/2014 at 18:000 Comments
I have ordered the stepper motors, drivers and power supplies.
X and Y axis motors:
http://www.omc-stepperonline.com/dual-shaft-nema-23-cnc-stepper-motor-114mm-25nm-23hs453008d-p-163.html
Z axis motor:
http://www.omc-stepperonline.com/3d-printer-motor-nema-17-168a-45ncm64ozin-17hs191684s-p-17.html
X, Y and Z will use these drivers and PSUs:
http://www.ebay.com/itm/400W-0-90V-0-4-4A-Switching-Power-Supply-Current-Control-Charger-LED-CCTV-K1D-/380913018968?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item58b02f6858
Rotation motor and driver:
http://www.omc-stepperonline.com/nema-14-bipolar-stepper-54v-08a-18ncm255ozin-14hs130804s-p-93.html
http://www.ebay.com/itm/CNC-Router-1-Axis-Controller-Stepper-Motor-Drivers-TB6560-3A-driver-board-TE-/111290455455?pt=LH_DefaultDomain_2&hash=item19e96d959f
