Field testing
A project log for Alcohol sensor
Using MQ3 alcohol sensor and a nokia display
detoDeto 07/12/2016 at 09:450 Comments
I went out with some friends to a local festival, and done some field testing.
On the good side, collected some data about the scaling of the raw numbers the device displays, but the prototype broke after 3 days of "constant testing".
Got some good ideas to the second version, like adding a button to hold the measured data and some layout updates.
