Power supply, zero crossing detector and triac switch
A project log for IR Light Dimmer v2
IR Remote Light Dimmer v2 - installed instead of wall switch!
traxtrax 06/15/2016 at 06:360 Comments
Here is a very simple capacitive power supply circuit, with triac connected across its terminals. Triac will be triggered with negative impulse.
References for power supply and triac control: http://www.st.com/content/ccc/resource/technical/document/application_note/a8/00/35/e2/62/e5/4c/14/CD00266635.pdf/files/CD00266635.pdf/jcr:content/translations/en.CD00266635.pdf
And a very very lazy 10minute implementation :-)
Next step: microcontroller to detect zero crossing and trigger the triac. Lets see what happens next...
Stay tuned :-)
