Altera Quartus Install
A project log for eeColor Color3
Reverse engineering the Color3
tom-verbeureTom Verbeure 04/08/2018 at 18:311 Comment
(Also published here.)
Since the Color3 board uses an Altera Cyclone IV chip, you need Quartus for all FPGA related activities.
I'm using OS X  on my lab PC (it's a beautiful old beast of Mac Pro), and since Quartus only runs under Windows or Linux, I need to install a virtual machine.
Here's my setup:
The Cyclone IV is supported by the latest version of Quartus (17.1 as I write this), but I'm installing version 13.0sp1 instead: this is the last version that also supports a Cyclone II. And since I have already have one of those popular EP2C5 mini development boards, I need support for that as well.
So 13.0sp1 it is.
When downloading, you'll always be greeted with the terrible Altera download manager. Cancel that, and just download the individual .run file.
To limit space, I only download the following files:
QuartusSetupWeb-13.0.1.232.run
cyclone_web-13.0.1.232.qdz
 If you want to use ModelSim Lite for simulations, you can also download that one:
ModelSimSetup-13.0.1.232.run
 I use open source tools for simulation instead: iverilog, verilator, and gtkwave.
If you run QuartusSetupWeb right after downloading, it will not work. This is because Quartus Lite 13.0sp1 runs in good old 32-bit mode.
So to fix that, you first need to install the 32-bit version of libc6. Like this:
sudo apt-get install libc6-i386
Once you run ./QuartusSetupWeb..., you'll have to press [ENTER] about a hundred times to get though the licenses.
At the end, you need to select which packages to install. Here's how it looks for me:
Select the components you want to install
Quartus II Web Edition (Free)  [Y/n]
Quartus II Web Edition (Free)  - Quartus II Software (includes Nios II EDS) (4424MB) : Y (Cannot be edited)
Quartus II Web Edition (Free)  - Quartus II Software 64-bit support (1090MB) [Y/n] :Y
Quartus II Web Edition (Free)  - Devices [Y/n] :Y
Quartus II Web Edition (Free)  - Devices - Cyclone II/III/IV (615.2MB) [Y/n] :Y
ModelSim-Altera Starter Edition (Free) (3547.1MB) [Y/n] :n
ModelSim-Altera Edition (3547.1MB) [y/N] :N
Is the selection above correct? [Y/n]:Y
Ready to Install
Summary:
  Installation directory: /home/vagrant/altera/13.0sp1
  Required disk space:  6129 MB
  Available disk space: 8433 MB
It's important that you also install the 64-bit version of Quartus II: the 32-bit version requires a lot of standard Linux libraries that are simply not supported by Ubuntu 16.04.
When everything is said and done, the installer will ask you if it's ok to start Quartus 64bit. Enter Y and you're good to go.
And then after you quit, it won't really work anymore, because you need to setup your environment:
In ~/.profile:
export QUARTUS_ROOTDIR="/home/vagrant/altera/13.0sp1/quartus"
PATH="$PATH:$QUARTUS_ROOTDIR/bin"
In ~/.bash_aliases:
alias quartus='quartus --64bit'
 Install 32-bit packages for your 64-bit Ubuntu:
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386 libpng12-0:i386 libfreetype6:i386 libsm6:i386 libxrender1:i386 libfontconfig1:i386 libxext6:i386 libxtst6:i386 libxi6:i386 libgtk2.0-0:i386
 We need the 32-bit packages because some parts of Quartus such as Qsys are still completely 32-bit based for 13.0sp1.
You will also need to configure your machine to give permissions for the USB Blaster cable. The instructions on this page worked for me, but I had to reboot the machine first after completing the steps.
Finally, if you want to run any nios2 related tools, you need execute this:
$QUARTUS_ROOTDIR/../nios2eds/nios2_command_shell.sh
Todo: put all of this simply in the Vagrantfile
Dave Rove wrote 04/26/2019 at 09:15 point
The Altera website has gone and now redirects to the Intel site where you have to fill in a detailed form requiring company details in order to download software. However, as of April 2019, there is still a working direct-link to download the Quartus II 13.0 SP1 tarfile for Linux from the old Altera download server:
http://download.altera.com/akdlm/software/acdsinst/13.0sp1/232/ib_tar/Quartus-web-13.0.1.232-linux.tar
