With a full set of #EVPR: Electric Variable Pitch Rotors completed, the next round of testing is getting close. One item on the to-do list to get ready is having dedicated vehicle mounts. In the past the vehicle was suspended by a loop of rope around the structural frame. Below is the previous setup.
![](https://cdn.hackaday.io/images/9655241541193415345.jpg)
The issues is that the loops tend to move around, and when the ropes go slack, the rope ends can hit the rotors.
![](https://cdn.hackaday.io/images/3075941541193548941.jpg)
With a brand new set of rotors, it'd be nice to keep them in good condition. So dedicated vehicle mounts were added.
![](https://cdn.hackaday.io/images/8345821541193961724.jpg)
The mount is 1" wide and is the same thickness used on the gussets. The black material is a non-slip drawer liner material, to keep the parts from chafing. No more movement of the mounts and no more impact issues with the rotors.
