Fancy hardware :)
A project log for Zymeter
A device to monitor the progress of fermentation (pH, specific gravity, alcohol, temperature)
anfractuosityanfractuosity 06/05/2014 at 19:250 Comments
Below is the FPGA board I will be building the prototype with (It uses a Cyclone II FPGA).  You can see it has a number of GPIO pins, which I can use for the ADC.
Below is the 2MHz ultrasound transducer in all its glory
