UV Laser Pointer and Green Laser Spectra Through 1 Quartz Cuvette
A project log for DAV5 V2.1 Spectrometer
The ZEN of simplicity Making the Complex...Seem Simple
david-h-haffner-srDavid H Haffner Sr 08/18/2016 at 21:480 Comments
2 Different Laser Wavelength's through 6 Different Solvents
http://publiclab.org/notes/dhaffnersr/08-18-2016/uv-laser-pointer-and-green-laser-spectra-through-1-quartz-cuvette
I wanted to test the resolution of my 0.09mm slit width, so what better way to do that then, aiming a laser through a quartz cuvette filled with 6 different solvents, and here are my results:
1 quartz cuvette was used for all spectral scans. Instrumentation: DH 4.0 v4 Spectrometer
Solvents used were:
1) Isopropyl alcohol [99.99% purity-certified by Duda Energy LLc]
2) Ethanol [95% purity-200proof] Consolidated Chemical Corp.
3) Acetone [99.5 + -%] lab quality- Consolidated Chemical Corp.
4)Ethyl Acetate - lab grade Consolidated Chemical Corp.
5) Methanol [99.65+%] Lab grade Consolidated Chemical Corp.
6) Distilled Water - Store bought [TDS meter used {total dissolved solids = 0}
