Step 1: What do we need
![Picture of What do we need](http://cdn.instructables.com/F54/EKMW/IPH4SPTQ/F54EKMWIPH4SPTQ.MEDIUM.jpg)
- LinkIt Smart 7688 Duo
- Grove – Led Strip
- Grove - Temperature&Humidity Sensor (HDC1000)
- Grove – Relay
- Base Shield V2
- Arduino Breakout for LinkIt Smart 7688 Duo
- Embedded Thermal Printer
Step 2: Wiring
![Picture of Wiring](http://cdn.instructables.com/FZA/DSID/IPH4SPTZ/FZADSIDIPH4SPTZ.MEDIUM.jpg)
Now, we should connect the Grove Modules to the Arduino Breakout for LinkIt Smart 7688 Duo just as the picture shows below.
Step 3: Setup the Linkit Smart 7688 Duo
![Picture of Setup the Linkit Smart 7688 Duo](http://cdn.instructables.com/FLO/M2WE/IPH4SPUP/FLOM2WEIPH4SPUP.MEDIUM.jpg)
The software work of the router consists of 5 parts, compatible with the previous router, control the relay from Mediatek Cloud Sandbox(MCS), upload the Grove Sensors to MCS, a website to write something for printer to print out, the code on ATmega32U4.
I assume you have been familiar with Linkit Smart 7688 Duo, if not, please clickhere to get started. Then go to the MT7688 terminal by SSH or serial.
Modify the configure file to change MT7688 into router mode.
vi /etc/config/network
Change the configure interface ‘lan’ and ‘wan’ as below shows.
config interface 'lan'
option proto 'static'
option netmask '255.255.255.0'
option ipaddr '192.168.100.1'
config interface 'wan'
option ifname 'eth0'
option proto 'dhcp'
We use the yunbridge for communicating between MT7688 and ATmega32U4, so, enable the yunbridge.
> uci set yunbridge.config.disabled='0'
> uci commit
Requests is the only Non-GMO HTTP library for Python, safe for human consumption. Requests allows you to send organic, grass-fed HTTP/1.1 requests, without the need for manual labor, I use it to communicate with MCS.
I use flask web framework for this Web APP, Flask is a lightweight Python web framework based on Werkzeug, Jinja 2 and good intentions. You can clickhttp://flask.pocoo.org/ to learn more information.
Next, install Python dependencies.
pip install requests flask Flask-WTF wtforms
Step 4: Configure the MediaTek Cloud Sandbox
![Picture of Configure the MediaTek Cloud Sandbox](http://cdn.instructables.com/FN3/RIM5/IPH4SPVE/FN3RIM5IPH4SPVE.MEDIUM.jpg)
MediaTek Cloud Sandbox (MCS) is a cloud based data service platform for Internet of Things devices. If you don’t have an account please clickhttps://mcs.mediatek.com/oauth/en/signup to sign up.
MCS has already provided some useful tutorials, you can create the prototype and test device in MCS step by step following here.
Then in my project I create a new prototype for Linkit Smart 7688 named LinkitRouter, and add three data channels for this prototype they’re Button Temperature and Humidity just as picture below shows.
Now, you’ll get the Device ID, Device Key and 3 Data Channel ID, you can find the information in the test device detail page, and we will need them later.
Step 5: Upload the Arduino Code
![Picture of Upload the Arduino Code](http://cdn.instructables.com/FG4/WMJX/IPH4SPW6/FG4WMJXIPH4SPW6.MEDIUM.jpg)
1. Download demo code at https://github.com/Lee-Kevin/20.IoTRouter
2. Click “Download zip” button on right side of webpage to download all codes.
3. Decompress the downloaded zip files to“C:\Users\Administrator\Documents\Arduino\” and remove “-master” in decompressed file name.
4. Launch Arduino IDE.
5. Click Sketch =>Add file to add routerBox_Arduino.ino file from“C:\Users\Administrator\Documents\Arduino\20.IoTRouter\RouterArduinoCode\routerBox_Arduino.ino”
6. Click Tools =>Board and select “Linkit Smart 7688 Duo” and chose the right port, as shown in the picture below.
7. Press CTRL +U to upload codes to your board. Wait a while, there will be saying “Done uploading”.
8. Congratulations, you have already completed the whole of the work on Arduino.
Step 6: Download the code from Github
![Picture of Download the code from Github](http://cdn.instructables.com/F6B/DDR4/IPH4SPWT/F6BDDR4IPH4SPWT.MEDIUM.jpg)
Now, we have already install the requirements, download the code from github.
cd ~ & git clone https://github.com/Lee-Kevin/20.IoTRouter
Navigate to 20.IoTRouter and you can find there’re 3 folders, RouterArduinoCode, RouterScript and Drawings. RouterArduinoCode is the code that should be run on Arduino, RouterScript is the Python code should to be run on Linkit Smart 7688. Now we mv the RouterScript to /root/.
cd 20.IoTRouter/ & mv RouterScript/ /root/
Navigate to /root/RouterScript/ and edit the UpdateSensor.py and relay.py using vi editor.
cd ~ & cd /root/RouterScript/
vi UpdateSensor.py
vi relay.py
Change the deviceID, deviceKey and dateChannelID to your device. As shown in the following figure.
Step 7: Setup the the startup script
![Picture of Setup the the startup script](http://cdn.instructables.com/F6B/2QQJ/IPH4SPYG/F6B2QQJIPH4SPYG.MEDIUM.jpg)
Then setting the startup script.
chmod +x router & mv router /etc/init.d/
/etc/init.d/router enable
/etc/init.d/router start &
And then reboot the router.
reboot
When the router is reboot done, you have done all the software work.
Step 8: Prepare the things for Hardware Work
![Picture of Prepare the things for Hardware Work](http://cdn.instructables.com/FT6/EJ1S/IPH4SPZE/FT6EJ1SIPH4SPZE.MEDIUM.jpg)
- 4mm wood
- M3*10 Screws – 8 PCS
- M3*8 Scews – 2 PCS
- M3*5+6 Studs – 2 PCS
- M3 Screw nuts – 10 PCS
- R30100 Nylon rivets – 4 PCS
- R2075 Nylon rivets – 6 PCS
Tools:
- 502 glue
- Scotch tape
- Screw driver
- Laser Cutter
Step 9: Laser cut the wood
![Picture of Laser cut the wood](http://cdn.instructables.com/F0I/KKES/IPH4SQ03/F0IKKESIPH4SQ03.MEDIUM.jpg)
In this part, we need to make an box as the picture below shows, this work is by my workmate Nosk, and he is an intelligent industry designer, you can download the drawings by click here.
Then we need to cut the the board using laser cutting. I guess you don’t have a laser cutting at home, you can find some in the hacker space near from you easily. If there's no hacker space nearby, you can try the Laser Cutting Servicesupply by Seeed.
Here's we use 4mm wood~
Step 10: Hardware Assembly
![Picture of Hardware Assembly](http://cdn.instructables.com/FXJ/7YD5/IPH4SQ10/FXJ7YD5IPH4SQ10.MEDIUM.jpg)
- Fixed the frame by M3*10 screw and nut. (Image1,2)
- Mounting stud on PCB, then fixed it on wood. (Image 3,4)
- Fixed sensor and relay on wood by R2075 nylon rivet. (Image 5)
- Fixed the printer. (Image 6,7)
Step 11: Shell Assembly
![Picture of Shell Assembly](http://cdn.instructables.com/F64/BN3V/IPH4SQ2J/F64BN3VIPH4SQ2J.MEDIUM.jpg)
- Fixed the RGB LED by scotch tape. (Image 1)
- Fixed both side wood. (Image 2, 3)
- Lampshade made of paper, fixed it by scotch tape. (Image 4, 5)
- Fixed the outside shell by nylon rivet, don’t forgot to install button. (Image 6, 7, 8)
Step 12: The finished look
![Picture of The finished look](http://cdn.instructables.com/FKA/QX7H/IPH4SQ3X/FKAQX7HIPH4SQ3X.MEDIUM.jpg)
Here is the finished look of the router.
Step 13: The Result
![Picture of The Result](http://cdn.instructables.com/FJR/VQEF/IPH4SQ4L/FJRVQEFIPH4SQ4L.MEDIUM.jpg)
Now, you can connect to the Linkit Smart 7688 Wifi AP, and input mylinkit.local:8000 or your 7688 local IP :8000 in your web browser, and you can see the Router Printer web page just as below shows. Input something in the textbox and click Print Message and you’ll find the Printer can print it out.
The go to the MCS website, and check your our test device, you can click the button to control the relay and view the sensor values just as picture below shows.
Step 14: Make. Invent. Do.
This project is made as an Open Source Project. It's a starting point. Let your creativity go wild with the mechanical, electrical and software design. Make the demo your own. Decorate it. Improve the work. No matter what, write a recipe about it.
Let's do something special for special people together.
Cheers!
