Shift Register board completed
A project log for 8x8x8 Blue LED Cube
512 LEDs driven by an Arduino via eight shift-registers and eight MOSFETs
Hari WigunaHari Wiguna 07/17/2014 at 00:380 Comments
Everything took longer than expected, but I am pleased with the result.
I did a continuity test after soldering each group of wiring.  That paid off!  The circuit worked the first time I plugged it in!
