Testing and assembling the first character
A project log for MOLBED Modular Low cost Braille Electronic Display
A project that I started in 2014, aimed to develop a low cost and modular refreshable Braille system
MadaeonMadaeon 07/19/2016 at 10:270 Comments
Testing the first character. At the moment an Arduino and 3 L293 are used to control the coils- h-bridges, each pin has a single coil. The key of this system is the magnetic interaction between the magnets that are free to move inside the pin and the retaining M2 nuts at each end. Power is used only to change from a state to the other one. The distance between the magnets and the nuts is quite important for a correct behaviour.
