Get the camera's image into the program.
A project log for Anna The Multibot!
Multifunctional robot to help bring the dream of a personal robot into reality.
dennisDennis 07/03/2016 at 23:190 Comments
First things first. In order to experiment with a vision system, you need a camera and you need to get the camera’s picture from the camera into a program. I configured the Tenvis camera to my local WIFI router. Follow the Tenvis easy setup in files.
I added a tutorial to demonstrate how to get the camera picture from the camera into the program. After running the tutorial, you should be able to display the camera’s picture in the form like the picture below. This is also a good first step to building a telepresence robot!
