Doubling capacity.
A project log for Garage Door Opener
An ESP8266-based garage door opening device
myles-eftosMyles Eftos 11/21/2016 at 21:290 Comments
So, it turns out the ESP8266-01 (at least the one I have) supports 1MB of storage. I had been butting up against the 512kB I thought I had, and it turns out I needn't worry.
Running this command:
ESP.getFlashChipSizeByChipId()
Will tell you what your chip supports.
This means I can probably incorporate Over-the-air updates, which will be handy. I still need to keep the image under 512kB (OTA needs the space to upload the new image).
w00t!
