The Build: Physical Portion
A project log for Realtime Cigarette Smoke Detector
A sensor meant to measure and detect cigarette smoke in public places.
caleb-hannemanCaleb Hanneman 07/11/2016 at 05:030 Comments
At this point I am designing the stl file that can be found in the files section of the project. It is being printed on my Printrbot Simple Metal at 196 degrees Celsius with a layer height of 0.1986. Truth be told most of the pieces of the project are simply attached using super glue.
