Ok, so before I can write the code to do the work, I need a couple of tests to validate / benchmark against.
Three problems:
- Detecting Blobs, and the resulting X,Y position + other data being true or close enough
- Bench-marking efficiency - using the same data and timing the processing steps will highlight areas to improve, flag diminishing returns on over optimized parts
- Experimenting with 'tracking'. In a sequence of blobs, being able to assign an arbitrary ID to each blob and maintain these IDs sensibly as they move
In order to generate this bench-marking data, I will simulate some 'dots' moving around, render them to an image, drop out the image, and save the dots 'actual' X,Y location and UID.
At this stage, I am pretty much defining the file format the whole MoCap system will record to.
