TOF Sensors arrived
A project log for Low cost 3D Lidar camera module
Low cost 3D 64 Pixel TOF camera
Frank.MuenznerFrank.Muenzner 07/06/2016 at 21:132 Comments
I get my raw TOF sensors, and i ask me if i can solder it, The pitch is 0.45 mm. I knew this sensors are small - but to see it...
Next steps are:
selecting Components
electrical and optical
PCB design ......
My question is : from where can i get cheap fixfocus glass lenses?
The type used in piCamera module could be usable if glass lenses are used.
Anyone could give me some info where i can find?
Frank.Muenzner wrote 07/11/2016 at 19:34 point
Thanks for your help.
The link to surplusshed is interesting.
For this project i want to use a standard mount because of availability and reproducibility.
Edmund  optic i knew, but as you said not for low cost.
I think i will use a classic M12 or M7 / M8 mount.
For the firts sample i will use a M12 mount lens system, from Eric's link.
Ted, I really like your 3D magnetic field scanner project, it's amazing.
Ted Yapo wrote 07/09/2016 at 04:26 point
I've purchased cheap (surplus) lenses from these places:
http://www.surplusshed.com/ (some really good bargains here if you look hard enough.  Check out their "lens finder")
http://www.edmundoptics.com/clearance-products/ (this used to be anchor optical surplus)
For top-quality (and top-dollar), of course, you can't beat Edmund:
http://www.edmundoptics.com/ very expensive
The other thing you might consider is using a standard C- or CS- lens mount.  Then you could use a wide variety of lenses on your device.  Cheap CS-mount lenses are made for security cameras, and C-mount (same thread, different flange distance) used to be a 16mm movie camera standard, so old lenses are cheap on ebay.
