Build Instruction 3
A project log for Android VLC Remote Foreign Language Mod
Why I wish more android apps were open source, and maybe some tips on how to customize everything.
linuslinus 05/28/2014 at 23:450 Comments
Ack-grep is awesome. If you haven't given it a try, you should. The syntax and usage are intuitive and easy. Check out build instruction 3 for the output of my first search and how easy it was to get started. Also there is another simple example of how to use ack-grep and a text editor to customize anything. Just find the command you want to change, swap it out and recompile.
