Re write
A project log for rain water irragation controler
monitor you water levels in your tank and control 4 irragation zones while monitoring the soil moisture for them
robRob 08/01/2016 at 07:030 Comments
well with the way things are going here
I'm set to start my first rewrite of most of the code look for some updates in the next few weeks . I will be building a nicer web interface and making a few changes to the firmware going to try to allow for 5 programs that allow you control multiple zones which should also allow for running zones more than once a day. also going to be adding automatic re populating forms so you don't have to refill them each time you want to make a small change
the plane is to allow picking zones the same you pick days currently and giving each one a binary bit so that 9 could be sent converted to 1001 and would be translated to zone 1 on zone 2 off zone 3 off zone 4 on which is how I currently pass my day selection from web to photon hopefully decoding binary like this wont be to hard in php once I sorted it out in C it wasn't to bad but I had a lot of help but this is low on the list for now i just want to get the redesign started
so if anyone is interested in jumping on board and helping me learn as we go with php for much of it this time I think if not at least the to make the form self populating I will need a little php
see you guys in a few days
