Generating the .DXF file from the image
A project log for Team Valor Light Up Badge -- #PokemonGO
A badge that will display your Team Valor colors wherever you go
Orlando HoilettOrlando Hoilett 07/16/2016 at 21:330 Comments
This is pretty straightforward. There are a number of online tools to allow you to do this. I used http://www.autotracer.org/. This site allows you to upload the URL of the image you would like to render and then save the file. Then I used Autodesk's online DXF viewer to view the image before sending it to a laser cutter.
