moar of the things
A project log for ramanPi - Raman Spectrometer
The open source 3D Printable Raman Spectrometer using a RaspberryPi and easy to find off the shelf components..
fl@C@fl@C@ 03/10/2017 at 08:082 Comments
So, I thought I'd throw a couple of these in for inspiration.... I'm really enjoying Fusion360... Anyone interested in helping with creating these?
This is the beamSplitterAssembly reborn into a simpler, and easier to print design.. No more of that tiny little carriage for the cube, this one is much more robust and a way simpler design..
Andrew wrote 05/25/2017 at 19:59 point
Hi, what programming language do you use to program the FPGA? I have experience programming a cyclone FPGA with VHDL
fl@C@ wrote 05/26/2017 at 02:04 point
Hi Andrew, I started out trying the mojo FPGA board using their proprietary language...but moved to the DE0-Nano with the Cyclone IV with the Xilinx ISE..  If you're interested in contributing, we can certainly use the help!!
