Build Instructions: Mirror Mount Assembly
A project log for ramanPi - Raman Spectrometer
The open source 3D Printable Raman Spectrometer using a RaspberryPi and easy to find off the shelf components..
fl@C@fl@C@ 09/25/2014 at 22:010 Comments
Note: This log entry is a living document. I'll be updating this post to reflect the current configuration as time goes on.. There will also be a log at the end of the post noting modifications to the log, etc..
UPDATED-----> 09.25.2014
This log entry will instruct you on building the Mirror Mount Assembly.
Tools Required:
Components Required:
Steps:
1. Print and clean up the plastic parts. Be sure to use the 3D printed part guidelines. All spurs and supports need to be cleaned as much as possible.
2. Place the 1 Newport Pyrex First Surface Laser Mirror 1" Model# 10R08 ER1 into the slot on the bottom half of the mirror mount.
2. Place the top and bottom halves together, and place the mounting screws in.. Tighten the back screw and then the front.. Don't over-tighten!
3. Grab four of the M2 12mm adjustment screws..
3. Insert and lightly tighten the four adjustment screws on the back of the assembly... Don't worry about alignment at this point.. That will be covered later in the system alignment series..
That completes the construction of the mirrorMount Assembly! Set aside and move to next build!
You can close this tab or return to the build instructions here!
UPDATE LOG:
09.23.2014 - New Entry
