PCB's arrived!
A project log for Under Cabinet LED Lighting Controller
An ESP8266 is used to control a 12VDC or 24VDC string of white or RGB LED's.
matt-meerianMatt Meerian 08/19/2016 at 03:030 Comments
The boards arrived from OSH Park today! I put a board into the enclosure base and then test placed several of the parts on one of the boards. The components seemed to fit.
Next, I'll try reflowing the SMT parts. I've used the hotplate method of reflow with some success in the past.
