​What are PUREmodules?
A project log for PURE modules
Simplifying development of low power wireless IoT hardware and software sensor prototypes with a modular sensor architecture
pure-engineeringPure Engineering 10/03/2016 at 22:250 Comments
These are the building blocks for IoT connected smart sensors. To quickly build a solution to your problem, grab the PUREmodules you need and assemble your solution today. There is no need to solder, breadboard, or wire anything. Once you have assembled what you need you can write your application how you want using your existing workflow or by modifying some sample code. We provide examples using Arduino environment to get you started.
