Feed Override
A project log for G Code Cleaner
Clean up your G-Code by filtering unnecessary points.
agp.cooperagp.cooper 08/20/2016 at 12:460 Comments
Override Feed Rates
Added two options:
  1. -G0 FeedRate
  2. -G1 FeedRate
These options override the file feed rates (i.e. deletes feed rates in the file and uses the option rate instead).
Example:
GCodeFilter.exe -i fish6.nc -o LaserFish6.nc -t 0.01 -l -g0 600 -g1 120
This line (usually in a batch file) overrides both the G0 and the G1 feed rates. Also sets "laser" mode.
AlanX
