First Screenshots of the Android App
A project log for WLAN Sinus Generator
A Sinus (0-40MHz) generator controlable via WLAN, using AD9850 and ESP8266.
jan-bJan B. 08/09/2016 at 21:270 Comments
The last few days I worked on the android apps. With it you can control the frequency and phase output of the DDS Generator. In the Tool section you can activate or deactivate both leds.
The Code is licensed under the Apache License 2.0. You can find the source here: Github . Under Releases you can find an signed APK of the app.
Here are some screenshots:
