First data analytics
A project log for Bluetooth Data Owon B35T Multimeter
Reverse Engineering Bluetooth Data
alain-mauerAlain Mauer 07/30/2016 at 19:230 Comments
Here is what I found until now. It is enough for the project I am working on.
The best way to see the Data is in Decimal. In Ascii code, most of the Data is not displayed correctly.
It's a data sequence of 14 decimal values. The sequence starts with the + or - sign and ends with a CR + LF
