pouring the concrete slab/ R 50 insulation under
A project log for Passive building construction from the foundations
First go at understanding the building code for a passive build home
macduff2macduff2 05/05/2018 at 15:011 Comment
macduff2 wrote 05/05/2018 at 15:02 point
The temperature  was 27 degrees C had to follow the heat in this placement
