In this tutorial, we'll go through how you can use Python to encode text into a QR Code and display it on the Onion Omega's OLED Expansion.
We will need to have support for git, Python, and the Onion OLED Expansion Python Module.
opkg update opkg install git git-http python-light python-codecs pyOledExp
Now we need to download the Python code that actually does all the work:
cd /root git clone https://github.com/OnionIoT/oledQrCodeGenerator.git
Now we have to make some QR codes! Navigate into the repo directory:
<span class="hljs-built_in">cd</span> oledQrCodeGenerator
And run the program, the argument to the script is the text that will be encoded in the QR code pattern:
root<span class="hljs-variable">@Omega-18C2:</span>~/oledQrCodeGenerator# python main.py <span class="hljs-string">'Wow, my first QR Code'</span> > Encoding <span class="hljs-number">21</span> characters<br>> Generated QR <span class="hljs-attribute">Code</span>: <span class="hljs-number">31</span>x31 pixels > Doubled QR Code <span class="hljs-attribute">size</span>: <span class="hljs-number">62</span>x62 > Initializing display > Setting display mode to inverted > Writing buffer data to display
This will encode the data and display the resulting QR code on the OLED Expansion:
View all 5 instructions
Onion.io
Doug Poole
pammyleong
Oleksandr Y.
Yes, delete it Cancel
You are about to report the project "QR Codes Using Onion Omega ", please tell us the reason.
