Using Adafruit 2.8″ TFT Breakout Board Pinout
TFT size is 240×320
Unknown LCD driver chip: 6809
If using the Adafruit 2.8″ TFT Arduino shield, the line:
#define USE_ADAFRUIT_SHIELD_PINOUT,
Check the code found that only identification information of the 9325 chip then can drive the LCD screen,direct assignment “return”.
The following is the code:
if(identifier == 0x9325) {
Serial.println(F(“Found ILI9325 LCD driver”));
} else if(identifier == 0x9328) {
Serial.println(F(“Found ILI9328 LCD driver”));
} else if(identifier == 0x7575) {
Serial.println(F(“Found HX8347G LCD driver”));
} else if(identifier == 0x9341) {
Serial.println(F(“Found ILI9341 LCD driver”));
} else if(identifier == 0x8357) {
Serial.println(F(“Found HX8357D LCD driver”));
} else {
Serial.print(F(“Unknown LCD driver chip: “));
Serial.println(identifier, HEX);
Serial.println(F(“If using the Adafruit 2.8\” TFT Arduino shield, the line:”));
Serial.println(F(” #define USE_ADAFRUIT_SHIELD_PINOUT”));
Serial.println(F(“should appear in the library header (Adafruit_TFT.h).”));
Serial.println(F(“If using the breakout board, it should NOT be #defined!”));
Serial.println(F(“Also if using the breakout, double-check that all wiring”));
Serial.println(F(“matches the tutorial.”));
//return;
identifier = 0x9325;
Then upload LCD screen and can start up
TFT size is 240×320
Benchmark Time (microseconds)
Screen fill 1321920
Text 191300
Lines 1091844
Horiz/Vert Lines 137464
Rectangles (outline) 100220
Rectangles (filled) 3068776
Circles (filled) 1218600
Circles (outline) 474972
Triangles (outline) 346464
Triangles (filled) 1671168
Rounded rects (outline) 218420
Rounded rects (filled) 3589960
Done!
