Tasks/Costs
A project log for Open Rover
The goal of this project is to create a standardized outdoor robotics platform, similar to the Turtlebot.
nerd.kingnerd.king 08/21/2016 at 18:062 Comments
Mechanical
Electrical
Software
nerd.king wrote 08/21/2016 at 23:02 point
The X1 will be the main ROS node and I will use a mini-Ethernet hub to connect the X1 to the motor controller(s).
Command and control will be done through the X1 and eventuallyy some sort of SLAM with cheaper off the shelf cameras.
Thanks for the question.
rkrishnasanka wrote 08/21/2016 at 22:43 point
How are you planning to integrate the X1 ?
