Now in 3d!
A project log for Science Tricorder by Olympus Heavy Industries
A multi-mode scanner and data logger based on Adafruit Feather & Arduino
queadlunnQueadlunn 08/07/2019 at 06:150 Comments
After quite a while I've started to work on the next version of the Tricorder! I've had the hardware partially built for a while now but I'm starting to get the casing worked out in 3d so I (and anyone that wants to) can print it. It's going to take a lot of work since it's my first 3d design like this. Once I test it out and can make some changes I'll upload an STL and the original 123dx files.
