Working 3D case, firmware upgrades
A project log for FLipMouse
A low-cost mouse replacement for people with motor restriction. Operated either by the fingers or the lips.
benjaminaignerbenjaminaigner 11/21/2016 at 10:340 Comments
The 3D printed case works!
After a few changes, like too small holes and so on, we have a fitting 3D printed case now.
We also altered the mouthpiece, using a cigarette tip (cheaper and easier to buy here).
In addition to the new case design, we also updated the FLipMouse firmware, including following new features:
Here are 2 pictures from the finished 3D printed version:
Modified mounting of the sensors:
If you want to build the 3D printed version too, you need a little bit different BOM:
Everything else is the same!
Happy building!
