Usage of FABI as an extended keyboard
A project log for FABI - Flexible Assistive Button Interface
The FABI allows control of a computer’s mouse cursor and typing desired keyboard keys by using buttons
benjaminaignerbenjaminaigner 08/21/2016 at 10:330 Comments
Maybe you know the problems of working with different keyboard shortcuts or key combinations which are often used.
You might experienced the same problem if you are located in a German speaking country and you have to program code: Most of the brackets are located on annoying positions (e.g. { is Alt Right + 7).
The solution is FABI!
You can setup 6 buttons in a part of wood and configure them to support your mainly used shortcuts.
It's possible to assign copy&paste, if/for/while combinations and also different shortcuts for other programs (e.g. Jump frames in a video editing software).
This is the setup I use:
Please note, that different keyboard layouts by your Host-PC are only supported by the Teensy microcontroller. The Arduinos don't provide different layouts by now.
Some extra pictures of the build:
I know, this is more of a dirty hack, but it's quite useful for me :-)
If you dig a little bit deeper to the configuration software, you will find the possibility to use different key setups with so called slots.
