Iteration 3 - Android app sending Json to ESP-01 via MQTT
A project log for ESP8266 MQTT Infrared AirCon Control
An amateur build of a monitoring and control system for the aircon in my baby's room, using an ESP8266, IR Led, JSON and MQTT protocol.
ShoeboxShoebox 10/21/2017 at 13:230 Comments
Quick update on the project...
Aircons are HVAC systems and receive the full state in every message - i.e. if you press temp down 1 degree, the remote actual sends the temp setting, the fan setting, the swing setting etc every time.  Previously I had to use a work around because the free android MQTT clients I found, could not send settings from multiple controls in a single message. I've written my own now,  am  iterating to remove the unneeded complexity.
I've developed a basic MQTT android app that can send the full state. I've started using JSON payloads in the MQTT messages, and I'm rewriting the firmware on the ESP-01 as well.
I'll write this up more completely another time and upload the code to GitHub, but for now here is a couple of screenshots,
And the latest iteration of the device... I've changed the power source to a 18650 instead of 2 AA... after losing 3 hours on a bug that was actually a power issue...   I've also broken out the reset pin so I can add back the ESP Deep Sleep function to extend battery life.
