Connect the Power Supply
A project log for Call Box
Pushing a button will sound a piercing alarm to alert a caregiver (in another room) that attention is required.
Mike RigsbyMike Rigsby 08/23/2016 at 23:540 Comments
After the alarm container has been printed, insert the wire from the 9 volt power supply through the hole in the container.
Now, solder the wires to the alarm module (where the battery was intended to connect). Be certain that polarity is correct.
