With this housing I can fix my isolation switch directly to the battery box.
Battery isolation switch housing to simplify attachment to battery housing.
bat iso switch box.stlSTL file for printingStandard Tesselated Geometry - 237.48 kB - 04/14/2018 at 01:34 |
I used ABS for this one as temperature in a automotive environment is not for the like of PLA. No rafts or supports needed. 50% fill. 3 perimeters for top bottom and sides. Very little cleanup needed.
