Testing the Prototype
A project log for Ask Brenda's Cat
A voice controlled indoor weather station for the visually impaired or those who have mobility issues.
brenda-armourBrenda Armour 09/04/2016 at 13:400 Comments
The first step was to wire the components in Node Red. I have two function nodes for each measurement to correctly extract the data for Alexa.
I used Freeboard to check if the response is correct or you can use the Debug node in node red. For those unfamiliar with Lux here's some info:
One lux is also the equivalent to 1 lumen spread over approximately 1 meter. A lumen is the measurement of the total amount of light that a source emits, such as a light bulb
Okay now for a trial run !
