Cabling AWG & length
A project log for Lead Acid Ah Capacity Tester/Logger
A genuine, automatic load tester that requires no heat sinks and can be built in 2 hours with all through hole parts. Based on a PIC 16F uC.
mosaicmercmosaicmerc 04/20/2015 at 19:230 Comments
Please note that for higher currents >8A you must use SHORT cables , perhaps 1' each and #14AWG or larger. Otherwise voltage bounce can destroy the FET driver in a minute!
