remembering the screen program
A project log for Silly software wishlist
Motivation to do some software projects by writing them down.
lion mclionheadlion mclionhead 09/08/2019 at 19:461 Comment
Lions used to discover odd UNIX programs by examining the output of ps on multiuser systems with actual multiple users.  When they got their own personal UNIX boxes, those days ended.  Screen was a very useful program lions once discovered, but forgot about.  Not sure if it was originally just used on vt100's & xterm ended up replacing it or if the resolution was too low to have more than 1 xterm.
It was forgotten for 20 years, but would be useful in today's world of having to run browsers in multiple accounts.  The lion kingdom's typical development environment has evolved into 5 xterms for 5 tasks which would best be consolidated:
openocd
telnet into openocd
builds
search commands
text editors
The basic screen commands:
ctrl-a c creates a new shell
ctrl-a n go to the next shell
ctrl-a p  go to the previous shell
ctrl-a " shows all the shells
ctrl-a ctrl-a toggles between 2 shells
More advanced commands:
ctrl-a d detach the current shell, making it a daemon.  You can log out without ending it.
screen -r reattaches to the daemon & shows the terminal output
screen -ls shows the daemons
Scrolling in screen:
Screen by default doesn't use the xterm scroll buffer, but has its own odd buffer which requires using its copy feature to scroll into.
ctrl-a ESC enters copy mode
cursor keys scroll back
ESC again escapes from the copy mode
The alternative is forcing screen to use the xterm scroll buffer by editing /etc/screenrc
This magic line should already be in /etc/screenrc & just need to be uncommented:
termcapinfo xterm|xterms|xs|rxvt ti@:te@
The xterm scroll buffer is not swapped when changing shells.  You still have to go back to abusing the copy feature for that.  Lions used to jump around the screen program like a pro & screen's disabling of the xterm scroll buffer makes lions believe it was originally just needed on vt100's.
There is a split screen mode, which defeats the purpose of multiplexing shells into a single terminal but looks neat.
The titles of the screens have to be customized.  In Linux, it's done by appending a kludge to print an escape sequence right before the command prompt.  It can't show the currently running program but it can show the prompt.  It takes some doing to delete all the other PS1 declarations & make sure this is the only one:
export PS1='`whoami`@`hostname`:`pwd`% '
# customize the screen title
case $TERM in
    screen*)
        # ESC k ESC \ tells screen to set its title
        # \w prints the working directory
        SCREENTITLE='\[\ek`whoami`@`hostname`:\w\e\\\]'
        SCREENTITLE=''
esac
PS1="${SCREENTITLE}${PS1}"
Ken Yap wrote 09/08/2019 at 22:40 point
You'll find that a screen program still exists but is mainly used for maintaining a persistent session. Nowadays with large screens widely available there is no barrier to opening up lots of xterms.
