Edit a text file on a phone in a browser
A project log for Silly software wishlist
Motivation to do some software projects by writing them down.
lion-mclionheadlion mclionhead 02/13/2024 at 20:110 Comments
There is a desire to edit config files & notes on a phone without shuffling files around, typing on the phone screen, or using busybox on ADB.
https://hackaday.io/project/138050-silly-software-wishlist/log/179072-web-based-file-manager-for-android
Webphone needs an editor which shows the file contents in a text box, has a save button, revert button.  Browser text editing is horrendous but better than nothing.  It would be the absolute minimum way of changing a text file.
After some heroic HTML POST handling, it was done.  Need undo or revert?  Just hit the back button.
There is 1 kaboom case.  If a text editor on the phone changes it & the user resends the POST in the browser, it'll overwrite the phone changes.    The post could contain an md5sum of the previous save & it could reject the post if the md5 doesn't match what's on the phone.
This became kind of a pain after a while.  It needs to retain the size of the text box in a cookie.
