So we need to make sure we give the compressor the same load as when it was in the fridge. I pulled out the evaporator ( the cold part) and carefully traced the path and measured to find how long the evaporate coil needs to be.
The small end on the evaporator is a restriction to keep pressure up, once it pushed through this capillary it passes through the dryer and then the condenser again to repeat the process.
I simple make the copper tubing the same length as the factory made their path to maintain the level of efficiency that the factory intended. Hmm I think I voided the warranty.
