Extending the Finger
A project log for BEOWULF
Robotic Exoskeleton for Grip Enhancement and Stroke Rehabilitation
rowan-ferrabeeRowan Ferrabee 09/20/2016 at 02:500 Comments
Once a working finger prototype was developed, we began considering how the four fingers could come together into a fully functioning hand assembly.
The goal of the remainder of the hand is simply to transfer force from the linear actuator at the wrist to the fingers. Firstly, a support plate had to be designed which would rest on the back of the hand and support the force transfer system.
Since there would be no one surface that would fit every user's hand, the back-of-hand plate was segmented into four components in a way that mimics the human palm's four metacarpal bones.
Springs were added to the inside of four force transfer rods to allow for movement of the fingers even after one finger has completed its movement.
Finally, a slot to translate the force from the linear actuator into each of the rods was implemented.
The whole system was designed and put into one big assembly that looks like this:
Finally a design we could show of :)
