Code is up!! - ¡El código esta disponible!
A project log for PR-Holonet: Disaster Area Emergency Comms
An easy to build, setup, and use emergency communicator for disaster-struck zones with no working power or comms infrastructure.
inventive.prototypesinventive.prototypes 08/13/2018 at 01:570 Comments
Hello Everyone!!
I'm happy and excited to say that the code is finally up! Please treat this as a very early alpha. HOWEVER, if you are the type that:
Then you are so totally my type!
The goal for this project is that anyone who needs it can build it, so if you take the time to pull and build and notice a few things that, uhm, make your experience... --- let's say, less than ideal --- then throw me a line. Post an issue on the github page and I'll slowly but surely get to it.
If you are NOT the coding type, then I honestly TREASURE your opinion as well. Remember this project is meant to help in emergency situations with emphasis on the people willing and able to help. No requirements for tech geniuses here (although they are always welcome).
Until the next log, hack away!
--Inventive.Prototypes
PS: Although I would love to see this project help others I'll make it clear that I am not making any warranties or claims to fitness - implicit or otherwise - as to the use of this project. Please understand that if you decide to use it you do so at your own risk.
¡Hola a todos!
Me alegra poder anunciar que el código para el proyecto esta disponible. Por favor, trátenlo como una versión alfa muy temprana. PERO, si eres el tipo de persona que:
¡Entonces eres mi tipo de persona!
La meta principal de este proyecto es que cualquier persona que lo necesite lo pueda construir, así que si tomas de tu tiempo para montar el proyecto y encuentras el proceso, digamos, no muy claro entonces déjame una pregunta o un comentario por medio de los "issues" en github.
Si NO eres el tipo de persona que sabe programar, también atesoro tu opinión. Recuerda que este proyecto esta diseñado para ayudar en situaciones de emergencia, con enfásis en la gente disponible para ayudar, no en los genios técnicos ( Aunque si eres un@ eres siempre bienvenid@).
Eso es todo por ahora, ¡hasta luego!
-- Inventive.Prototypes
PS: Aunque me encantaría saber que el proyecto es útil para otros quiero dejar claro que no doy garantía de uso o propósito - directa o indirectamente - relacionada al uso de este proyecto. Por favor entienda que si decide usarlo, lo hace a su propio riesgo.
