ph/ORP circuit
A project log for AquaPic - Aquarium Controller
Reef tank controller used to monitor various parameters such as temp and pH, and also control equipment such as pump and lights.
skyler-brandtSkyler Brandt 08/04/2014 at 22:310 Comments
Recently I breadboarded the pH/ORP amplification and offset circuit. I don't have any probes or cal/check solutions so I just set up a voltage divider with a trimmer pot to simulate the different voltages. Everything worked as I expected. Other than that I've been working on code here and there, focusing mainly on UI.
