Rogue: When they come out... does it hurt?
Wolverine:
Every time.
Yeah there's some sharp edges there alright. XD
I've been experimenting with materials again trying to create a tough skeleton system for Pandelphi Cub, having picked up some Polypipe which is light and strong.
I've used this before on numerous occasions, and made some great hardware with it.
This was filmed using the scrap I experimented on :-D I can now film myself filming myself. Better not go there lol, we'll be here all day.
An experimental servo mount. I had to do a lot of cutting and measuring to get that to fit, there must be an easier way.
There is as well. This worked out so much better than I hoped.
The screws that mount the servo also join the plates together so they dont move. Its rock solid and will easily deal with the 13kg torque from these evil servos. Metal-Gear Futaba clones with uprated motors and electronics. They are badged as 'Robot' servos, but I see no difference to the mounting and interface from the ones around half a decade ago. My stepdad used to fly RC, and nothing has changed since... Bad show guys, Especially Turnigy and Futaba, the two biggest names out there.
Make us a hinge, dont just change the description you bums. >;-P
All the tape does is hold down the flap so it doesnt rattle, the two side cheeks cross and the screws go through both, and into the pipe at the other end. It's ludicrously strong and all in one piece, better than a PLA print and probably stronger than an ABS one as well.
Joints in pipe are a total pain in the butt. Polypipe is slippery and smooth, but get it formed properly and its extremely rigid. I copied a bicycle handlebar for this, figuring metal and plastic would behave similarly and it worked really well.
A little heat on the tube and that will straighten right out. ;-)
I did have a little trouble interfacing to the servos, until I retried the trick I used with Cardware...
The Dead Yoke...
A cross of material with the arms folded out has the same geometry as the Hip Unit but it doesnt have to be round and braced to take the strain like cardboard.
This bolts onto the end of a tube that has been split into flanges, or bolts to another one back-to-back to make all the moving joints.
I love how the material pulls around and smooths under my fingers, its a very organic way of working with it and very satisfying.
Once this is finished, all that remains is to make a panda skin from fabric with a double pocket in the stomach. One to take all the hardware which doesnt even need mounting, and another with a zip to take the Echo Dot.
