3D modelling and more problems in Z axis or solutions(maybe)
A project log for Deep Foundation Laser Scanner
This project try get the dimensions about a deep foundation without a danger to the responsible for the excavation survey.
laio-athos-nevar-fonsecaLaio Athos Nevar Fonseca 04/20/2018 at 04:490 Comments
Today I'm modeling the basic 3D and making some tests with the Sharp sensor. My biggest doubt was about the deflection of the IR beam and now, its ok. It's a relief.
Now I'm working on the system that will make on Z axis movimentation.
Maybe I use a fixed point of the cable on level 0m and a reel to variate the elevation. To get this data, I can use a servo motor and convert his turns to Z axis distance.
