The good, the bad and the (probably) good news.
A project log for Deep Foundation Laser Scanner
This project try get the dimensions about a deep foundation without a danger to the responsible for the excavation survey.
laio-athos-nevar-fonsecaLaio Athos Nevar Fonseca 05/18/2018 at 03:130 Comments
I don't know exactly how it's works...
When I did the first test with the Sharp sensor on a mirror, I don't know, or I can't remenber if I did all the tests that could be possible. Or if I did one test and it worked well and I jumped the other tests.  But now, I bought a lot of mirrors and neither of then works well.
I bought a dieletric mirros and normal mirrors.
The cause:
The Sharp sensor works by a triangulation of the emitter and a scale on the reciever. When I use a rotating mirror, these results can't be registered on the scale.
The solution:
I will change the Sharp sensor to the gy-530-vl53l0x
I will purchase this sensor and make a lot of tests.
