Materials used to build pulse motor generator:
1.fidget spinner with iron insertions – the flywheel
2. three neodymium magnet discs
3. two small solar panels – power source
Details :
Voltage: 5V
Power: 1.2W
Current: 240 mA
Material: Monocrystalline
Size: 110 x 69mm
4. Step-up Module with adjustable booster power supply module
AeroSemi MT3608 1.2MHz 2A Step Up Converter
2A maximum output current
2.0 to 24VDC input voltage range
28V maximum output voltage (trimpot adjustable)
93% peak efficiency (~200mA output current at 5Vin, 12Vout)
36 x 17 x 14mm
5. Coil iron less from a syncronous motor 230 V – used to capture the magnetic flux gnerated by the pulse motor
6. bobbin – coil iron less used to produce a repulsive force
7. reed switch
sciencetoolbar
