Battery Drill Through Test
A project log for Solar Powered Mobile Device Charging Hat
Solar cells in the hat charge an internal LiFePO4 battery, which can then charge any mobile device via USB
msummers123msummers123 12/01/2016 at 22:320 Comments
I was actually surprised how well this test went. Turns out the heat protection worked quite well, and the pouch correctly vented the battery away from the wearer.
