After failing with using the internal oscillator I have switched to Arduino Board as a prototyping platform.
![](https://cdn.hackaday.io/images/8383761525407818790.jpg)
First thing noticed is that the image is perfectly stable using the crystal.
![](https://cdn.hackaday.io/images/64351525407728193.jpg)
The correction of the grayscale shades after the resolution test pattern were another story. I needed a spare clock cycle to add 3 to the color pointer, then it was necessary to move one instruction some memory positions before and thus save a cycle. some tweak is still necessary, though to get the correct stripe colour after the resolution line pairs.
I have produced a spreadsheet that can calculate all the resistors based on values of VOH, VOL and the sync voltage level when the 75ohm load is attached (e.g. 0,15V). I have a good link on how to solve a matrix equation with rectangular matrices using standard functions of a modern spreadsheet program. No Scilab necessary!
![](https://cdn.hackaday.io/images/7118871525408014727.jpg)
The spreadsheet resulted some values and I have used the most close value available in my parts bin. HOWEVER, I have noticed that the value for the resistors on most significant bits are somewhat critical.
for instance the calculated and used values were:
Resistor | Calculated (Ohms) | Used (Ohms) |
R Sync | 211 | 220 |
R Bit 4 | 195 | 220 |
R Bit 3 | 390 | 390 |
R Bit 2 | 781 | 750 (1k5//1k5) |
R Bit 1 | 1563 | 1K5 |
R Bit 0 | 3131 | 3170 (2k7+470) |
R Pulldown | 187 | 150 |
I have lost some time trying to figure out why I couldn't have a good linear (progressive) gradiend after the middle of the screen, and finally discovered that I should have used a value closer to 190 Ohm than the 220 Ohm I have used. At the end I have put another resistor in parallel so the equivalent resistance dropped to 180 Ohms (1k//220) and finally get a good gradient!
![](https://cdn.hackaday.io/images/3396071525408087578.jpg)
The image with correct resistor value can be seen below
![](https://cdn.hackaday.io/images/4196871525408319634.jpg)
Some work has yet to be done to correct the color stripe right after the last vertical line. But I am happy for now.
